Re-capping vintage main boards with radials
uniserver
Ya i know this makes some of you cringe. I personally don't really have an opinion any more. As long as it works when i'm done, and the customer is happy, that is all I really care about.
Anyways, this customer gave me a stack of boards to do, he wanted all radials. He feels radials are going to last longer, and are more robust then SMT electrolytics.
So I have a couple styles i'm using to make sure and lay them flat on the PCB... I, like most people hate christmas trees, and pad rippage.
1. Nip and lay - (if you have enough space)
2. Trim and bend over - (if you have space issues)
3. Diagonal Cut - (if you have to approach the pads at an angle)
Just a few tid bits i'd like to share, might be helpful if you find your self with a bag o radials and feel like doing a re-cap.
I personally prefer to stick with SMT OEM Lytics, I just just like the stock look my self.
They are much quicker for me to install, then an all radial thing like this.
Unknown_K
I used some radials on a few IBM PS/2 floppy drives and they look ok and work great (odd ratings that I could not find cheap SMT's for). Never used anything but SMT for my Macs.
Ike
I've used nothing but radials on my macs.
The SMD components look better and may last longer, but the radials are easier to replace when they crap out. Plus I can find then much easier locally.
And I like myself to believe that when one of the radial caps leak, it wont damage the board as much because they are floating...
I like the 'Trim and bend over' approach Uniserver, didn't think of that myself.
