I recently bought a Performa 450 (LCIII) off eBay as it was my first ever computer and I always regretted getting rid of it. I booted it up and it started fine off the hard disk, but the speaker was making a whining sound. I attributed this to the usual bad capacitors, and when I opened it up there was indeed electrolyte leaking so I proceeded to change them. All seemed to go well, but when I had finished and booted up the Mac, the hard disk drive can no longer maintain constant RPM. It seems to be only getting intermittent power. I went back to check my soldering work (reflowing the solder in several places) and as I did so I inadvertently ripped one of the solder pads clean off the board. Stupidly hoped to be able to re-attach it with a little solder on the bottom, but this has simply resulted in a black mess beneath the pad and it still won’t attach properly.
So I currently have:
A Mac which cannot supply constant power to the HDD
And - a solder pad unstuck from the board, unsure of what it affects or how to fix it and with possible damage underneath it
can anyone help me out on what to do next? I am quite a beginner at this, and as this Mac is getting rather rare I really hope to be able to salvage it!
