Tales of a bombed Quadra 700: the "short" lived victory
Big Ben
Hello,
Let me tell you the terrible tale of the bombed Quadra 700.
Do you feel that sensation traveling your spline? Fear! You name it!
That’s the feeling I had when I took off the shelf this freshly bought Q700 and I heard something moving…
Removing the top revealed what everyone fear the most… an 1/2AA battery socket loaded with a bombed Maxell floating around.
Damn it! Let’s remove the PSU and the drive holder to get a sneak peak of the carnage…
Well this isn’t that bad! Is this Quadra 700 the first Mac I’ll actually save from a lithium bomb?
Some cleaning after it looks quite nice! Almost everything fall off and a bit of work with a spludger and the iron did the rest.
I won’t say it looks like new, but it is quite nice!
With a bit more solder iron work I managed to clean the battery support viad and holes.
Except I ripped off the ground pad on both sides, it was too damaged.
But does the inner still work? Does it need a wire patch?
Let’s find out! Taking the multimeter in continuity mode I connected both probes and it ringed!
Hourra! Another ground test, it still ring hourraaa….. ay?
Wait.
I messed up, this pin on the molex is not the ground.
I moved both probe to the two molex on the board, both have 5V and GND shorted.
Damned.
Slowly I removed each tatalium capacitor I found on the 5V rail, hoping it was just an old cap failure…
Except it’s still shorted and caps where fine.
A "short" lived victory against the bomb, a long battle now begins to find the short…
chiptripper
Are you certain it’s a proper short? Have you tested for resistance as well as just using the continuity setting? What reading do you get?
My probe will sometimes buzz like a short when there’s simply very low resistance. Mac II / IIfx have some circuits like this.
Big Ben
I wasn't, but the resistance is pretty low, around few ohms, I took some time to check against a working Quadra 700.
Good to know, Quadra 700 have a very low resistance between the 5V rail and the ground, no need to freak out like I did.
I started to continue cleaning up the bombed Quadra 700 case, I'll give it a try tomorrow I guess after I re-soldered the caps.
Can't wait to try the PowerPC card that came with.
