therieau
Since this is absolutely the place to contemplate this question, I've been thinking about how to make my Wallstreet mobile again. I had a thought:
What if you took the innards out of an existing dead battery pack and installed a cheap USB power bank in the case and used it in the slot? Could you run the machine with just the power leads connected, or would it complain if it didn't see anything connected to the charging pins? Would the machine be able to tell the level of charge just from the power output?
Basically, does anyone have a schematic for the charging system I can review before I spend any money?
I look forward to hearing your thoughts.
EDIT: By the way, has anybody used these guys? http://laptoprescue.com/Powerbook-Battery/
