macinbot
Scored a Powerbook 170 and couple other PBs as mentioned in this thread: viewtopic.php?f=3&t=16943
The bezel is a little loose on the hinge and one side. Byrd and Trash80toHP_Mini gave me some good tips for securing it. Before I was going to set to work on that, I decided that I was going to wait until I could source a power supply and make sure it actually booted.
Well, I was moving one of my external HDs and decided to look at the power supply. 12v / 2A. Powerbook 170 take 7.5v / 2A. Polarity was correct, so I thought I'd give it a quick try. Plugged it in, pressed the power button and "BONG"! It started. Screen showed a bunch of garbled graphics and went into an endless reboot cycle. I was a bit disappointed, but decided to give it another go, but with the laptop battery pulled. Bong, followed by garbled graphics, followed by HAPPY MAC! Welcome To Macintosh came shortly after and then the extension parade and finally the desktop.
Not too much exciting on it. It's maxed out at 8mb ram, 60mb HD and running 7.5.5. I think the system software is a bit rich for it. I'll try and figure a way to get 7.1 on there. I opened a shareware program up and it said that I had been using the software unregistered for 15999 days. Thought that was amusing.
Things I need:
Does it take a special version of System 7.1 (or at least an extension)?
Will running it with a 12v instead of 7.5 harm the Mac or power supply?
Anyone have a take-apart guide for the PB 170?
Things I need:
