How do you reseal the screen?
I have recently ruined two decent PowerBook 180 screens that had minimal dark edges, trying to reseal. I used Imperial Vacuum Sealent because it was much cheaper than vacseal.
However both screens now still work but are completely distorted with black boxes, lines, and blurriness. Whats funny is if I leave it on - despite the distortion - the edges are not getting dark.
I thought the first screen was overbaked in the oven (190 degrees for 5 hours) - but the second screen I did not bake, and the same issue happened.
My process was:
1. Removed display / backlight assembly from the PowerBook case.
2. Used a pliers to turn the 30 notches on the back of the backlight assembly and remove the screen
3. Used painters tape on the screen glass, and put sealant around the back of screen. Waited two days.
4. Put screen back on backlight assembly, moved notches back into place.
5. Turned on, Screen ruined.
I have tried using a toothpick and some isopropynol (alcohol) to remove the added sealant from between / under the black spongey pad and the glass on the back of the screen. I was hoping it was just the sealant causing an electrical conductivity issue with displaying the data - as the black spongey bar seems to atually be a conductor to some pins for display data. However, removing the sealant from the screen (which comes off like flaky plastic) did not revert the screen to normal.
For now I have two ruined PowerBook 180 screens that I wish I would have never done anything with.
If you are going to try and seal the screen - I would not remove the screen from the backlight assembly, and instead just try putting sealant on the display corner openings, instead of fully removing the screen from the assembly. It seems if the screen is removed from the backlight assembly, it is runed.
