Should not be a problem as long as the cells contact the heat spreader with no more insulation thickness than the existing cells' sleeving. The batteries run and charge cool until the very completion of charge when the cells start to get quite warm. The power manager is looking for this temp rise over ambient as a signal (one of several, the manager is also monitoring voltage and keeping some running estimate of charge state from a time and current drawn/delivered standpoint) for switching from high rate charge to trickle charge. I think the heat spreader is not for heat sinking, but rather sampling the temperature of all of the cells and bringing this sample over to the strip PC board where a temp sensor is seeing the temperature of the air near two adjacent cells plus the temperature conducted to it from the heat spreader to the PC board to the sensor leads. Whatever cells you use should come with insulating shrink sleeving and can be taped down onto the heat spreader. Then, to help hold down the cells, small foam strips can be put on top to fill the gap to the top cover. Or, there's even enough room to put an inverted homemade springy battery socket thingy that incorporates the original safety overcurrent/overtemp devices and makes contacts to those economical retail store tabless cells. There has been forum discussion elsewhere on the merits of not soldering directly to tabless cells, and some have even built spotwelders using big caps like those used in monster car audio stiffening applications. Leave the vents of the cells and case unblocked in the event gases need to be vented....Would the temperature and space thing be a problem? I wouldn't think they would get very hot.
Use the highest mAH cells you can find. If you're going to go to the trouble of rebuilding your battery, you may as well max out the capacity at the same time. Longer battery life is always a good thing.What kind of capacity should the AA cells have?
Currently, the total capacity of the battery is 3500mAh, so if the AAs were to match that one, and I used 8, they would need to be about 450mAh each.
However, most of the AAs and AAAs in the catalogue are rated at around 1500mAh.
I'm guessing we don't want too much capacity. Anyone got any suggestions as to what would be ideal?
Where are the specific cells you were looking at? There are a lot of them on that site.Well, there are 8 cells, and if the cells were 1500mAh which are listed in the catalogue, the total would be 12000mAh.
Smaller cells are avaliable.
Supplier is http://www.rapidonline.com
Your math is not quite right. A mAh is not energy, so you don't just multiply the number of cells by the mAh rating. It is the product of current (milliamperes) and time (hours). If I have two cells in parallel, then I get double the current, and thus double the mAh. If the two cells are in series, the mAh rating does not change because the current does not change; the current is simply delivered at twice the voltage.So, if I used the 1500mAh cells, that would give a total of about 12000mAh. Wouldn't that take way too long to charge though, even if it did last longer?
I figured it was something like that. 12000mAH is way too high for a laptop battery. The laptop I am using now has a 4400mAH battery in it.Your math is not quite right. A mAh is not energy, so you don't just multiply the number of cells by the mAh rating. It is the product of current (milliamperes) and time (hours). If I have two cells in parallel, then I get double the current, and thus double the mAh. If the two cells are in series, the mAh rating does not change because the current does not change; the current is simply delivered at twice the voltage.So, if I used the 1500mAh cells, that would give a total of about 12000mAh. Wouldn't that take way too long to charge though, even if it did last longer?
The original pack consists of 3500mAh or 4000mAh cells. So, using 1500mAh cells in a purely series combination would give you just 1500mAh, and hence shorter, not longer, runtime.
