Byrd
Hi,
I received my PB 3500/Kanga G3 Powerbook the other day, and set out fixing it up with a new HD and general spruce up, it came with 5GB HD and 64MB RAM (32 + 32MB)
I also have a Powerbook 3400 with 144MB RAM (16MB + 128MB), and thought I'd be able to put the 128MB stick into the Kanga - it looks exactly the same and fits in both machines. However, while the 32MB stick works in both machines, the 128MB only works in the 3400 (the Kanga boots with the 128MB stick but it is not detected).
Googling around it appears my suspicions were correct; not all modules 64MB and above from a 3400 work in a Kanga, but there are conflicting reports about this; some have said the RAM works fine in either machine, others no.
Does anyone have any experience with this, or can offer suggestions?
Thanks
JB
Thanks
JB
