Aeroform
Based on the good looks of the area / chips (no battery leakage whatsoever), would you still consider it possible there could be a faulty chip there? Or would you recommend replacing UD8 / UE8 first and see (although I'm unsure those chips could cause that error to start with)?.You don't, you replace them all. That is what I do. I don't question it anymore as I got tired of messing with dodgy chips.
You can sit there for hours chasing your tail to figure out where the bad one is based on a logic analyzer or you can just replace them and save a whole bunch of time.
Really appreciate all input I can get as I don't really have any skills in this department.
