MICRON Xceed Grey Scale video card with the works for sale on Buyee! I wonder how much this one will go for?
joshc
It will still go for mega bucks. The reverse engineered one isn't available for sale right now and a lot of people will still value having the original.
3lectr1cPPC
I suppose so...
I wouldn't pay that much for one if I was in the market, I'd just wait for the recreation to officially release, but it wouldn't surprise me.
joshc
Has it? Where was that? I missed it.
It's not a direct reverse engineer/clone of the Micron card, it is based on a different video card to provide a similar result.
Me, @cheesestraws, @Paulie and I think @CircuitBored have them installed in our SE/30s at the moment.
No, that is what confused me. I know about the Formac clone. I just hadn't heard of someone doing the Micron card.
Some of us aren't quite as posh and have to bodge things.
Is that a right angle adapter w a maccon installed?
The riser is one of Bolle's PDS to accelerator and PDS, with built in ethernet (only the RJ45 is ethernet, the 15 pins are both video). The video card is where the various crimes were committed.
Kevinlenane
The riser is one of Bolle's PDS to accelerator and PDS, with built in ethernet (only the RJ45 is ethernet, the 15 pins are both video). The video card is where the various crimes were committed at
Ethernet built into the riser? It doesn't come out? I had to turn my Macon vertical and stack the Micron on top. That stack right now nukes my whole machine - which I believe is a power issue as both work separately. I also have a tiny clearance issue w that rig up.
The riser is an ethernet card yes. You can change the slot it uses to avoid conflicts. I've also struggled with the powersupply with this setup. My original Formac card is thirsty. I've put that on the back burner for now.
If you're interested in the riser drop @Bolle a message.
Kevinlenane
Sorry but this isn't the card? Or does the Ethernet card stick in the accelerator slot?
Bolle
This should make it obvious what’s going on.
Breakout board with RJ45 (and Db15 and VGA video connector in case of phiplis photo) connected to one of my adapter/ethernet combo cards.
