Macintosh TV Case Question
Scott Baret
Like most Mac TVs, my unit has a few minor scuff marks. Since the computer is black, not platinum/beige like most Macs, I'm curious as to what the best method for removing minor white marks would be.
One possible solution I thought of is Mother's Back-To-Black. This is a substance typically used on the old black plastic car bumpers once they have become sun-bleached. I had purchased this for my old Volvo and now have a lot of it left over (as I no longer have the Volvo). It worked great on the car so I'm wondering if it would do the same on the TV set. (The Volvo didn't have any white scuff marks on its black bumper but did have the typical uneven fading in some spots which comes with age on any black bumper; this compound made the bumper look uniform). Of course, the plastics are different on the computer, but I thought I'd mention this before I consider the potentially damaging "magic eraser" (which gets rid of marks but also removes plastic texture).
I'm going to assume retr0brite isn't an option. (Unrelated to the TV, I'm wondering if it IS an option for a white Apple Pro Keyboard; these tend to get yellow easily).
Byrd
For non-destructive, safe cleaning, isopropyl alcohol wipes work well. However, I'm a real fan of the "magic eraser" and suspect it would do a good job here, if used very gently - just try it on the base first :)
Otherwise, look into black vinyl dye (which you could potentially apply with a small paintbrush to the affected areas), which will bring it up like new. Auto stores or hobby stores sell it.
JB
mcdermd
I'm telling you, a 50-50 mix of 91% isopropyl and acetone. It won't damage the plastic and will take off 99% of anything. I have even used it on clear plastics with no issues.
FlyingToaster
I'm gonna try that 50/50 mix sometime. But..I tried the magic eraser on my MacTV and I don't really notice any damage to it, got rid of the drywall marks and looks fine
