uniserver
Basically what you want to do is use Nail Polish Remover, Set the battery upside down in a tubber ware and fill up about a 1/4 inch past the seam,
let it soak for about 4 hours... ( this i did not do ) i was impatient, finished with a dremel.
you can see the seam that i did let it soak some and it came right apart with the twist of a flat head.
Anyways I found a good replacement, It's 6v and 5.0 AH, Fits nicly!
19.99 at batteries plus.
Check pictures for exact model #
