Nathanplus
So I'm starting a new topic to update my old one. Check out the whole story on my original issue. After finally getting a new fly back for my mac plus the fast ticking never changed. I checked the voltages on the caps and sure enough the flyback still is not getting enough power. So what I did was first heat up the caps to see if any of the 33 and 22uf caps are bad. They didn't change any thing other than speed up the ticking a little. I have never got it to stop ticking while using the heatgun. Then I thought it was my motherboard so I drowned it in vinegar carefully using an exact-o knife on corrosion and blew under neath every chip on the board to get crud out. This obviously it didn't do anything. Also during all that I cleaned the cable and tried the voltage pot, to see if the voltage was too much or too little. Nothing changed can someone point me in the right direction I'm still at a dead end.
