Macintosh IIsi bank A RAM issues
8bitbubsy
I have a Macintosh IIsi that would give the sad mac chime since it had severe issues with onboard RAM (bank A), so I desoldered the RAM chips and their bus transceivers (74ALS245AD) as they were corroded anyway. The board now chimes and boots from floppy or HDD, but I get a black screen. It syncs, but the picture is all black. I didn't have the right VGA adapter before, so I couldn't test if it gave a video output before I desoldered all the stuff.
This makes me wonder, is the video framebuffer fixed to bank A, even if bank A is empty (desoldered)? Would this also mean that a IIci can boot with RAM in bank B only, but would show a black picture? If anyone could test that, that would be great.
Also, would it be possible to force bank B to be bank A (if that didn't happen already), or does that require a ton of rewiring? There's a lot of lifted pads for the onboard RAM + bus transceivers, so I'm not going to bother trying to refit that stuff.
Video is physically wired into bank A, it won't give built in video without bank A.
8bitbubsy
Yes, a lot of broken pads. Anyway, I already went ahead and forcefully scrapped components from the board.
Took the SWIM out, in case it's possible to manually re-wire it to a DIP28 socket so that I can use it in my Macintosh SE (together with FDHD ROMs).
I'm not sure if it would be compatible, would have to ask someone that knows.
