Arisotura
I'm running into a weird issue with my IIsi NuBus adapter. Basically, if I put a Lapis ProColorServer II in it, the Mac doesn't boot -- it gets stuck on the gray pattern screen, doesn't do anything else, doesn't display any cursor or boot icon, doesn't try to access SCSI.
But, that's the thing.
If I put a Mac II high-res video card in the adapter, the Mac boots fine, and that card works fine too.
If I put the Lapis PCS in my IIfx, it boots and works fine.
I did a little test -- I added an interrupt switch to the IIsi, put in the Mac II HR video card, and went to the debugger to see if all the NuBus address space is read/writeable, and it is. What I wanted to see was if one of the NuBus transceivers was bad and causing these issues, but the Mac II HR video card would still work because it only uses the working lanes, but I'm not seeing any problems there.
Any ideas what might be causing this problem?
