Nubus video card in Iisi with adapter.
crazyben
Cheaper here, but still kits.
Got any friends that can solder? They're pretty easy to build, could get two, one for them, one for you.
Make sure you get the red one. The yellow one... I got the yellow one first time and it came with the wrong parts and didn't work.
I can do solder. I have recapped few Macs and psu. Is this what I need to get. There are 3 options.
Yup, the first one. 1 to 50MHz (mine actually reads up to 60, but then doesn't go any higher). It's a red PCB. Those sellers often don't supply the instructions, but I have the PDF, will dig it out.
joshc
Tattletech do not show adapter whatsoever.
That's not what was asked - does it recognise the FPU? In the main section it should show if there's an FPU or not. Forget about the PDS adapter. Does it recognise the FPU at all?
joshc
Also I don't think my point about checking if anything is hot/cold was looked at yet - that's a basic check that can be done without any tools.
Yes, check what PDS cards you have and let us know.
crazyben
Sorry for responding to testing the card. I was not at home. I just tested the card and after running the computer for 10-15 mins. Chips are cold to touch in the adaptor. Unfortunately I cannot run the tattletech as screen in my floppy emu is not working. I have bluescsi external but I don’t how to run tattletech image from there. In regards to PDS card only one I have is apple 2e in LC.
crazyben
So I have working floppy emu and can run tattletech. What am I looking for in there? @Phipli received the crystal oscillator tester. Will assemble it tomorrow.
