haemogoblin
Hi guys
I have a slight problem and i was wondering if anyone else has suffered this. I bought a Classic off ebay earlier this year, it seemed perfectly fine. Tho sometimes the icon for the floppy would take ages to appear after inserting a disk.
Now today, I have turned the Classic on and discovered all the icons inside the hard drive have vanished. If i load up office, I can navigate the drive and folders if i go to open a document. But they do not show on the via the desktop interface.
I have disabled extensions and performed a rebuild, but it has not fixed the problem. If i do a "find" and say type in "Documents", it will find and open my "Documents" folder and the icon will appear along side the System folder.
I'm beginning to think it might be wise to format the drive and make a fresh install, there's not much on the drive other then a few applications Aldus Pagemaker, Claris. Which while I would like to keep for nostalgic reasons, they are not licensed to me.
