old_hitech
I have a Macintosh SE/30 with a SCSI2HD with many applications and files that I have acquired and created over 5 years. The SD card in the SCSI2HD drive is not accessible with the back cover installed. As a result I have not made a backup copy of the SD card contents. My plan was to use my FloppyEmu (FE) to copy a disk image from the internet to my SE/30. I put the FE onto the rear disk drive port and turned on the computer. I did not know this, but the last time I used the FE was on my Macintosh Plus as a HD20 drive. Well, the SE/30 started to boot off the FE in HD20 mode and before I realized what was happening I saw a message on the SE/30 screen that said the system 7.1 (on my SCSI2HD drive) was being changed to system 6.08 that was on my FE HD20 drive. I hit ‘CANCEL’ or ‘STOP”, and then turned off the SE/30, but the damage was done. I removed the FE drive and restarted the SE/30 and it would not boot. I got a message on screen that stated the drive is not recognized, do you want to initialize the drive?
Disappointed, I turned off the SE/30 and remembered that I had the BMOW ROMinator II installed on my SE/30. I turned on the SE/30 and pressed ‘R’ to boot from ROM. The ROM booted to System 7.1. I was able to see my SCSI2HD drive contents. All the Apps, Games and files were intact and useable. I looked at the System folder on the SCSI2HD and saw that it had some system 6 related files and a few other files. Outside of the System folder was the Finder with a 7.1 version number. I was glad to see that all my files were in good shape.
Now, I would like to know how to rebuild/replace my damaged System folder and make it bootable again.
I do have some System 7 install 1.44 MB disks as well as System 7 “Tuneup” disks. Should I use these?
The problem I see is that these diskettes have an archive installer file and do not have a System folder that I can easily copy over to the SCSI2HD System folder. Will using these disks force me to initialize the SCSI2HD drive?
One other idea I had was to swap out the memory card on my SCSI2HD and install a new memory card and install System 7 on it, then copy the new System folder contents to a 1.44MB disk and then re-install the original SCSI2HD memory card and copy the System folder from the 1.44 MB disk to replace my damaged System folder.
I’d appreciate any recommendations/suggestions.
