andrewgurn
I decided to purchase a MacEffects Performer PDS 68030, the 33MHz version specifically, for my SE. Unfortunately, I am having a lot of trouble with it.
My SE has 6.0.8 installed on the internal SCSI HDD, and I have a 7.1 disk image on an external BlueSCSI.
Before installing the hardware, I downloaded the "Performer 2.1.1" SIT file and extracted the contents on the SE. For 6.0.8, I placed both the control panel file and extension file into the System folder. For 7.1, I placed the control panel file into the Control Panel folder and extension file into the Extension folder.
I successfully booted into 6.0.8 twice, but subsequent boots, on the "Welcome to Macintosh" screen, error out with a system exception of type 11, or it'll just freeze without loading any extensions.
I have never successfully booted 7.1. When trying to boot, I get a system exception with the message being "System 7 Tuner". I thought maybe I should move the previously mentioned control panel file to the System folder, but the result is the same.
I cannot boot either with the accelerator installed and the control panel and extension not installed.
The SE runs fine w/o the accelerator and software installed.
Could this be faulty hardware, or am I doing something stupid on the installation somehow? If anyone has any ideas, I'd be happy to hear them.
