Kendall's Collection and Finds!
khannonnd
It seems I have started to have enough Apple stuff to warrant my own thread!
My current collection consists of:
(1) Macintosh Portable 5120 (which Uniserver, Techknight, and Canby have been instrumental in helping me bring back to life)
(2) Two Macintosh Pluses
(3) Powerbook 180
(4) Powerbook 540c
(5) Powerbook G3 Wallstreet "PDQ"
(6) Graphite iBook SE 466mhz
(7) 450mhz Cube
( :cool: Macbook (2008 aluminum unibody)
(9) 15" Macbook Pro (2.4ghz i5)
(10) 13" Macbook Pro (Late 2013)
(11) eMate 300
(12) Newton MessagePad 130
(13) 10GB scroll wheel iPod
This is my current set up (the other machines are either in cases or in my closet)  The Apple poster is a 1980 dealer foam board advertisement.  I got it from my local dealer several years ago when it was cleaning out its back.  Also seen are my mid-late 1990s MacAddicts/MacHomes/MacWorlds and the "Iconic" book of pictures of Apple products.
khannonnd
That poster is super sweet! Now you need a 128k to keep the pluses company :) :)
I am hoping I may have a bead on a special (and super affordable) 128k.  I will know for sure this weekend.  Fingers crossed.
I feel bad for keeping my second Mac Plus in the closet since it is in great physical shape and works perfectly.  I am keeping it and a third Mac Plus motherboard as parts machines should the one I have on display ever need help.
I also forgot to include my two iPads (one first gen and one retina mini iPad) in my collection!
Also, I guess I should mention my biggest collection fail ever.  Once when I was in eighth grade my computer teacher gave me an SE/30 she "found" in some closet at the school and had no use for.  This was in 1998.  The thing was in impeccable shape and had some accelerator card in it.  I don't recall what it was exactly, but at the time my family had a Performa 575 (with a 33mhz 680CL040) and I remember that the accelerator card was faster than that.  Well one day I was carrying the machine across the home and dropped it smack on the solid wood floors.  Both the case and the CRT screen cracked.  Being all of 14, I figured it was now worthless so I just put the machine out in the garbage.  I wish I had (1) not dropped it and (2) after I dropped it been smart enough to salvage the motherboard and other parts...
khannonnd
Today was an EPIC day for me and Craigslist.
First, I responded to a Craigslist ad advertising a "1985 Mac 512."  for $45.  Comes with the Apple carrying bag, keyboard, mouse, and software. I go and buy it.  Get it home.  Its an original 128k Mac.  He assumed it was a 512k mac because he got it for free from his employer in 1985.  I felt bad, so I called him back and offered to give it back to him since he didn't know what he had.  He declines but says he would accept a small "nominal" amount in addition.  So I go back and give him an extra $160 to make it around $200.  It works perfectly except for the internal drive is likely toast.  The mechanism for ejecting seems to get stuck even after lubrication and it doesn't want to read disks even when it accepts them.  I have removed the drive and tested the machine off of an external 800k drive.
It also came with some nice software.
Second, I received an Apple IIc, with software and power supply, for $40!  It came with Four Apple branded disks: (1) Getting down to BASIC; (2) An Introduction; (3) Exploring Apple Logo; and (4) The Apple at Work  It also came with an EA disk "Skyfox"
Pictures attached!  I'm pretty excited!
khannonnd
And the Software that came with the Mac.  I have no idea what a Flight Simulator would look like on this thing, but I guess I will find out.
Tiptoeturtle
It might be a good idea to try to make extra copies of the Mac diskettes in a later model of working twin floppy (or internal + external combination) Mac with two good diskette drives, before you do anything else with those diskettes.
Also, you might try using something like a pencil in the cavity in the metal hub of the media to manually rotate the diskette media until they stop squeaking and turn freely (if they don't turn freely now).
khannonnd
GREAT idea.  I am going to go do that right now.  I am trying to find a way to find a replacement, working internal 400k drive for this guy.  The external drives work, but I can only plug one of them in at a time at all!  I guess I will go use my Mac Plus to make these disks.  If I do this on a Mac Plus, will I be able to format the disks to be 400k so they can work with the original mac?
khannonnd
I am also confused by the serial number on the motherboard.  It starts with "LB."  None of the websites I have gone to has been able to decode the number.  I thought the letters at the beginning said where the machine was made, and I am not familiar with where "LB" machines came from...
Tiptoeturtle
It should work on a Mac Plus with an old enough configuration of the disk operating system, but at some point with later models or upgraded operating systems the support for 400KB single sided diskettes was ended. If you take a blank new 800K diskette to begin with, and initialise that as a 400K, somewhere in the disk initialisation process the dialog box will give you a choice of formats: 400K versus 800K. If you do not reach this dialog box there is something changed from the original Mac Plus, and you need to solve that problem before attempting copying the 400K original software (I think).
I suggest you try to find and buy a box of brand new double density (720K or 800K) 3.5" diskettes of high quality, if they are still being made.
I suggested you use a system with two diskette drives to avoid having to reload each of the source and destination diskettes several times into the one drive during the copy process, because a 128K Mac cannot copy a (full) disk of 400K size in one pass. I do not know how much RAM a Mac Plus needs before it can copy a 400K diskette with only one pass.
You are also better off doing this in a system with two external diskette drives or some other combination that avoids a situation where a defective source disk gums up your systems boot 3.5" diskette drive (if any).
khannonnd
Interesting, I looked up the Serial Number under the screen, and it does list the Model as M0001W.  However, the motherboard is, in fact, a 128k and the back plate says it is Model M0001.  Odd.
LazarusNine
That's an awesome find (on both counts). It was cool of you to call up the seller and offer a bit more money for it. Enjoy!
khannonnd
When did Apple start making the M0110 keyboards with colored Apples in the bottom left corner?  I have never seen that before...
Gorgonops
Moderator
Staff member
Re: the questions about making floppies, Disk Copy 4.2 will run on a Plus with System 6 and is capable of imaging and restoring 400k disks. It's what I used to make floppies for my 512k. (I even have a Localtalk->Ethernet bridge set up so I can drop downloaded disk images into a file share on a linux server and directly image them from there. One of these days I'd like to find a 9 pin phonenet adapter so I can try putting the 512k directly on the network and skip the Plus intermediary, though.)
