IT'S ALIVE!!!
Elfen
As a favor to dad, I recapped his IIfx for him. It was just two (2) caps - 47µf @16 cans that goes bad, they are on the right side, one under the power switch and another by the top RAM SIMM Sockets. They are very tight spots to solder in.
I'll post pics later, but in the very least the can caps have another cap area for a larger sized cap to go on. But I ran into problems.
1) Those leaky caps were glued down on top of being soldered on! I had to use a finger nail to pry off the plastic disc the cap rested on and there were two tiny red glue tabs. They were almost impossible to clean off! Scraping of off with a screw driver or pick proved difficult and I almost cut a trace further down on he board when the tool slipped off the dab of glue. So I left it there. I them desoldered the solder from the removed cap area and from the adjacent cap space. It definitely needed some cleaning with q-tips and acetone, and the goo spread to a large are for such a tiny cap - 4in sq (2in X 2in)!
2) Dad got the caps from Trag, THANKS TRAG! But because of the tightness of the area (and the large soldering iron dad uses) soldering it where the old cap was proved difficult. But soldering it on the adjacent space was perfect, though tricky. Tricky due to the space I worked in and the size of the iron. But I got them in there!
I found a couple of batteries and reassembled the IIfx. After plugging it in, it took a while for for it to turn on. In fact it would not turn on at all. So I tried jumping it with a third battery. Nothing. Then the phone rang and I had to answer it. I came back and pressed the power button before giving up on it. It turned on with a "BONG!"
Without a hard drive, it gave the flash "?" in a Disk Icon, so it works! I managed to get Norton's Emergency Boot Disk to get it running. So it does boot, though the floppy needs a cleaning and lubing.
Yay me! Dad is going to be so proud, though mad that I did it because he wanted to do it. But at least I got it going and I have not fixed a Mac since the late 1990s!
Notes:
Just 2 leaky caps killed this machine. 1 is by the power switch and a lead from the power switch goes to it, so that has something to do with it. It's hard to imagine that something so small can takedown the whole machine, but it did. Then again, it was a 10¢ switch panel light bulb that took down a whole jetliner!
The space was tight, but then again, the soldering iron was big, so I need to get dad a smaller iron.
Needs:
It's going to need its floppy cleaned out, another floppy added, and a hard drive. Other than that, it works! RAM is unknown as Norton's Emergency Boot Disk does not show that information.
Any hints as to what system to put on it? And where to get RAM for is since its so specifically oddball.
Again, I'll post pics up later.
olePigeon
You should just make your own account and join the community. :)
As for the IIfx, the RAM can be difficult to source, and expensive to buy.  Hans Strupat at Micromac has IIfx RAM doublers.  They turn a single IIfx RAM slot into 2, so you can use more low-cost, smaller RAM chips instead of the really expensive and relatively rare 16MB SIMMs.
I can give you his contact info if your dad's interested.
Elfen
Thanks for offers. I'll pass on the account here for now, but maybe in the future I may join. It took dad some 5 years of lurking this place before he joined. If I join, it wont take 5 years.  :)  I do have a busy life though so my attendance will be spotty, and I do not own an old Mac, just an Intel MacBook Pro. And its not just me, he taught all 3 of us Mac service and repairs. Those were some fun years.
Post up the information about the RAM Doublers, we're not the only IIfx owners here. Just one of the few to get theirs up and running again.
Now, about that IIfx. I was hoping that someone more informed can explain how 2 lousy caps could effect a Mac to not turn on at all, though I seen one of those caps were was tied to the power switch, so that could do it.
~Nicole
Juror22
I found it difficult to remove that as well, then later (and accidentally) found that a small chisel tip on my soldering gun will take off the glue that is sometimes beneath the caps (kinda like a hot knife through butter) without any adverse effects.
Elfen
Just did a floppy drive tear down, clean up and assembly. It's probably hasn't worked this good in 20-something years, though I need to look at the ejection system again - where the pinion hits the plate, the plate is slightly bend. Still looking for a new HD for it, though I have a few candidates I could take, format and put into its bay. The hard drive in there now is from my Q950.
