Mk.558
Yup.
Just like the M1 Garand Thumb Club, I have now entered the presitigous Solder Pad Lifter Club.
Changing caps on my SE/30 motherboard. Regrettably not as good as this chap,, I lifted a pad. And my solder joints...Well I suppose we'll find out if there's a problem?
What to do now? I looked on the backside and frontside for about 10 minutes trying to chase the pattern. Oh, if it only were so simple...It appears I might have to run a wire to the underside of the board. Or could a small wire to the whatchacallit on the surface which runs down to the bottom of the board work?
14 Megapixel photos below: (And yes, I saw that capaciter I missed near the 470uF)
Also, how do I check to make sure all the caps have good connections? Some are really tricky. The one near the ROM SIMM is easy to check, as is the one near the PDS slot.
