so just to help out future people, you ran a wire from
ASC pin 41
to
GLU pin 77
looks like if that one goes, then so could this one too.
GLU pin 74
to
ASC pin 42
Whenever I get scratchy sound, I always take ASC off, scrub the pads really good with flux and wick,
Sometimes i will scrap the SM a little from the pad if i see some rot.. just to make sure there is a good connection between the pad and the trace.
flood all the pads with solder and flow the chip back on and most of the time that fixes fizzy sounds issues.
