bobo68
Hi,
I acquired an SE/30 some time ago and it worked but started to show first symptoms of SimasiMac. Some weeks ago I gave it to a friend who has good soldering skills to do the recap. I gave him just the mainboard with everything removed.
When I got the board back and installed it, the SE/30 greeted me with this SimasiMac "on steroids":
The Mac shows the mouse pointer, I can move it and it shows the flashing "give me a boot disk" question mark. The pattern looks like a combination of the jail bar pattern and a checkered flag.
I decided to replace all caps again (this time I used tantalums, except from the big axial types of course). I recognized that my friend had ripped one the pad of C6 (plus side). I connected the plus side of the cap with pin 7 of chip UB11 with a wire. Still I got the same symptoms.
I then thoroughly washed the board and inspected all chips for blobs of solder and reseated the ROM chips and RAM. No change. I visually checked the underside of the board: all clean and well. I tested all caps for correct connection to ground or the respective other parts of the board. Everything seems normal apart from C1 where my multi meter shows a resistance of 500 ohms on both pins (to ground and Pin 12 of J12). I used the replacement and pinout jpeg posted on this board and Apple's schematics as a reference.
So now I'd like to ask the experts if they recognize this kind of SimasiMac. What is the cure or what can I do to further diagnose the problem? I have a scope and multi meter.
Any help is much apreciated.
Best, bobo68
Best, bobo68
