Bunsen
Admin-Witchfinder-General
NOOOO!!! Duo ditchers are shot at dawn around here [] ]'>
First step, read the profile of both models on lowendmac.com (from "mac specs" in the top navigation bar)
Then realise that all of these symptoms are common, fixable and have been encountered by folks here and at applefritter* dozens of times. Realise that the power adapters work, and you have a floppy drive and/or the Dock to do system software installs.
Then look at the fun fixit project you have in front of you, all free!
The batteries will be flat, if not dead. Leave the Duo on the charger (but not running) overnight or longer to get some juice into them.
Try removing the battery and the power, press the rear button and hold it down for a count of 60 seconds. Then put the power back in, but not the battery, and try a boot. Then try with the battery.
The 210 has decent specs for 7.1.
For the sticker goo, try naptha (sold as lighter fluid). A small drop on a cloth and rub away. Do a patch test on the underside first.
* btw the integrated search at applefritter is bloody useless. Use Google with "site:applefritter.com" after your keywords instead
This is known as the "tick of death". Google that and duo-dock and you'll find details of the single capacitor that needs replacing in the power supply.The Dock simply makes faint ticking sounds when I plug it in
There's no picture?"Make sure that the logic board mounting screw that also serves as a battery contact is installed. (Screw should be installed on contact located on right side)" - what is this about?
