BadGoldEagle
Hi all
Been thinking lately about buying a Tibook, the 1.0GHz one. Problem is, the slower 867MHz model has the same model number. I know later powerbooks had a sticker in the battery bay allowing you to properly identify the config when the battery was removed. I don't think the Ti has the same feature, does it? I ever had one so I can't know for sure.
According to everymac.com, the 867MHz one shipped with a 40GB HD, and the 1.0GHz with a 60GB hard drive. Thing is, the 60GB HD was available as a build to order option for every Powerbook model at that time. I don't think there's really a way to tell them apart... But I hope I'm wrong and that someone here will correct me.
I forgot to mention that the HD is missing in the one I'm eyeing.
