jholt5638
I just ordered a Quicksilver 733MHz Single CPU I plan on installing it in my Gigabit Ethernet Logicboard. From what I have read it should work as along as supply a 12V to the 4th mounting hole. It also says that normally the heatsink interferes with the second ata connector but since I have the board in a ATX case other sources say it should be fine. I am comfortable with changing the jumpers on the cpu card but should I instead use the firmware hack to overclock the Giga's system bus to 133MHz? I am running pc133 RAM already so there should be no problem there.
Do I have the basics of what needs to be done?
1. modify ether the Firmware to overclock the system bus to 133MHz or adjust the multiplier to x8 on the CPU
2. add a 12V rail to the 4th mounting hole of the CPU.
Anything I missed?
Anything I missed?
