You need a hub or a cross-over cable rather than a standard drop-cable.You don't even need the hubs for this sort of thing.
I've used an LC with a cross-over cable, even.I thought the G3s and up had autosensing ports, so either a straight or crossover cable would work.
I don't think anything in Apple's product line without Gigabit Ethernet autosenses. This Apple knowledge article base backs me up on that. Remember of course that only one end of the pair has to support auto-mdix for it to work. Thus if you've plugged, say, a G4 Powerbook into G3 doorstop, then it worked because the newer machine could do it.I thought the G3s and up had autosensing ports, so either a straight or crossover cable would work.
Never suggest to people unfamiliar with basic home networking to get a hub. Always switch because they do not know any better and may well go find a real hub instead of switch.You need a hub or a cross-over cable rather than a standard drop-cable.
As long as they like being close.So people should be told patch cable instead
I don't know if anyone makes genuine "hubs" anymore, at least for consumer use. The last thing I looked at that said "hub" on the outside of the box, a really horrible cheapest-thing-we-could-find Linksys of about 2004 vintage, was actually a switch. (Confirmed via tcpdump.) Which was a bummer because we specifically *wanted* a hub for the application in question. (don't ask.)Never suggest to people unfamiliar with basic home networking to get a hub. Always switch because they do not know any better and may well go find a real hub instead of switch.You need a hub or a cross-over cable rather than a standard drop-cable.
Non-invasive packet sniffing? Stress testing using an artificially slow network? Testing UDP broadcasts? There are lots of legitimate applications where you really do need a hub.Which was a bummer because we specifically *wanted* a hub for the application in question. (don't ask.)
The first one. I was looking for a cheap solution to outfit a whole lab full of development machines (testing threat detection software) with traffic-sniffing taps and inexpensive desktop hubs, one per machine, was the first thing that crossed my mind.Non-invasive packet sniffing? Stress testing using an artificially slow network? Testing UDP broadcasts? There are lots of legitimate applications where you really do need a hub.Which was a bummer because we specifically *wanted* a hub for the application in question. (don't ask.)
I would like to use a hub so i can hide it and so if i get some more of my macs on the network i can just add them inYou don't even need the hubs for this sort of thing.
as for my G3 and G4 i don't know if they do or don't, ill see if I can find outI thought the G3s and up had autosensing ports, so either a straight or crossover cable would work.
I am familiar with basic home networking, but the networking that I have done is under OS X 10.5.8, and i have done networking in the graphic arts department that i am in at school. as for if I have a hub or a switch i know that i have a hub because: A) it was used in our shop as a hub for our computers in our department, B) it says hub right on the front.Never suggest to people unfamiliar with basic home networking to get a hub. Always switch because they do not know any better and may well go find a real hub instead of switch.You need a hub or a cross-over cable rather than a standard drop-cable.
