This seems to be a semi common issue, so I wanted to get all my notes in one place
bsteckler:
Replaced flyback with the one from Technotronic Dimmensions(same part number, but different revision), recapped analog board. Fine for about a month, then had this issue. Replaced PRAM battery, issue is resolved.
Has left machine powered on for 30+ minutes, issue has not returned, so its safe to say it's been resolved.
ried:
Stock flyback, intermittent issue. When the video is messed up, no sound either
If they leave it overnight, it works fine for about 5-10 minutes, and then same issue happens.
Tried 2 logicboards and 2 personality cards, fresh pram battery
Steve/Mac84:
Same issue on his trash picked molar mac, reseated RGB connector on personality card, resolved.
verified with steve, no pram battery
Me:
When I got the molar mac, sound/video worked fine, but the CRT would click/make a spark noise and flash. Bought a new flyback from TD.
Swapped it, now have the same issue as above(with no sound). I did remove the PRAM battery at the same time, but I just tested it with a meter and the voltage is pretty much zero, so I don't think thats it.
Verified voltages coming off of the back of the flyback(-120v, 30v, 40v)
reseated personality card, and connectors on personality card, same issue.
Next up I'm going to reseat all the connectors on the analog board/neckboard. But not sure when I can get to that.
I saw some talk above about the 12v rail, I double checked on the molex connector on mine and it is showing 12v(and 5 is showing 5)
linear on twitter:
Before flyback replacement, no video at all.
After flyback, same issue
At this time, I'm suspecting it's a connection issue with the RGB cable going between the personality card, and the neckboard.
