Apologies if I missed something again but I haven't seen where bsteckler reported that a new PRAM battery resolved this.bsteckler:
Replaced flyback with the one from Technotronic Dimmensions(same part number, but different revision), recapped analog board. Fine for about a month, then had this issue. Replaced PRAM battery, issue is resolved.
Has left machine powered on for 30+ minutes, issue has not returned, so its safe to say it's been resolved.
Since you have +12V at the molex connectors, if you feel comfortable doing so, you may be able to rule out power to the video amp IC by taking the shield off the CRT neck board (if there is one) and measuring voltages on the IC. The chip in question will probably be the only one with a heatsink on the neck board, and the datasheet/pinout should be available online. In my (limited) experience there should be at least one positive supply of around 10-20V and a second one around 50-100V.I saw some talk above about the 12v rail, I double checked on the molex connector on mine and it is showing 12v(and 5 is showing 5)
I stripped it and reflowed the solder joints on the PS. I think maybe one of the power cabled got crimped when somebody was putting the MB tray back in but not sure. To be honest the thing is so large that I moved it to the garage on a dolly and its been there since (doing other projects and just lazy). I did find a SCSI ZIP and larger HD for it so when it gets fixed it will be complete.I just reseated my RGB cable to the neckboard, same deal.
@Unknown_K any luck with the one you picked up with this issue?
So you didn't resolve the smeared display issue before storing it? The search for a solution goes on.I stripped it and reflowed the solder joints on the PS. I think maybe one of the power cabled got crimped when somebody was putting the MB tray back in but not sure. To be honest the thing is so large that I moved it to the garage on a dolly and its been there since (doing other projects and just lazy). I did find a SCSI ZIP and larger HD for it so when it gets fixed it will be complete.
video amp IC is mc13282epApologies if I missed something again but I haven't seen where bsteckler reported that a new PRAM battery resolved this.
Caution would need to be taken when measuring things on the neck board, however, as the G2 and focus voltages are also present elsewhere on it (usually on the order of several hundred volts, and a couple thousand volts, respectively).
Checking 9 & 17 would be a good idea. Probably not much to gather taking DC measurements of the inputs.Should I check
Pin 9, 17 (power supply voltage)
And then
2,4,6,8,10,12?(Video amplifer inputs)?
Yep!G2 and Focus are the 2 wires coming off the flyback I assume?
I'll hopefully have a chance to check either tomorrow night or this weekend.Checking 9 & 17 would be a good idea. Probably not much to gather taking DC measurements of the inputs.
Yep!
The MC13282 appears to just be the video pre-amp. On the AIO neck board, it actually seems that the video amp that drives the CRT cathodes is implemented discretely rather than being a single IC (basically the whole bottom half of the board including Q303, Q307, Q311). If P302 and P305 have their pins labeled on the back side of the board, it might be easier to verify that the amp is getting what it needs by measuring voltages on them (e.g. on the tray-load iMac, there are pins on its equivalent of P302 specifically labeled 6.3V, 12V, 79V, and 127V).
I disassembled it, took off the neckboard and cleaned everything with compressed air and alcohol swabs. Did a real, solid cleaning job on the entire inside of the machine. Re-installed the neckboard and ensured it was fully seated against the CRT, and that all cables between the neckboard and the analog board were seated firmly, plus the RGB cable and the two red lines coming from the flyback. Plugged in the machine and started it up. No chime, so I figured it was in the same condition as before, but held down Cmd+Opt+P+R and zapped the PRAM, subsequently heard the boot chime and the display turned on as normal.For @ried , current advice I can give to you with this is, reseat all the cables you can. Including the RGB cable that goes to the neckboard(if you're comfortable with working in a CRT). Also, maybe put a fan against the mac for a while to cool it down, and see if you have any luck with the display being normal?
I checked with mac84, he has a g3 AIO board on his bench, headphones plugged into personality card, and it chimes.
so there also seems to be an issue with my personality card? will have to do some more digging with that
