demik
Was working on this since a few weeks. Since it works, I'm gonna post that here.
Long story short, while talking with folks around here, one common issue we had was that while Extended Keyboards are great (and still my favorite keyboard), they are kinda big for test benches or if your retro corner is small. That and we had too much dead AppleDesigns
The following idea was reusing the keyboard controller from a dead AppleDesign into a custom new keyboard.
Please note that this is ISO only for now, but everything including PCBs will be put on GitHub for people to mess with !
I only tested with an ALPS ISO 341-0001 Controller. Others controllers will probably need a different PCB
- A dead AppleDesign keyboard
- 70 MX styled switches (5 pins recommended)
- 65% Apple styled keycap set
- custom PCB
- 2U keycap stabilizer
- some tools (a Dremel would help greatly)
• Cut every leg as close as possible to the PCB
• Convert plate from ANSI to ISO
• Remove batteries holder, USB receiver. Cut case for ADB cables and ADB socket
• Reassemble PCB / gasket / plate / switches
• Route cables. You may want to use some glue on the panel here
• Keycap time and it's done ! Please check if the ADB socket hole can accept actual connector, you may need to enlarge it somewhat
Myself
- Case: Tester68 translucent black case
- PCB: Black, red LEDs
- Switches: AEBoard Naevies v2 (Alphas), Cherry MX Clear (Mods)
- Keycaps: Keychron ISO-FR ABS
@Paulie 's keyboard
- Case: Tester86 translucent purple case
- PCB: Black, blue LEDs
- Switches: Cherry MX Black
- Keycaps: Keychron ISO-UK PBT Retro
Mandatory family pics (AEKII uncle for scale)
If you gave any questions, please do ask.
On a side note, We know that there is at least 2 or 3 ISO AppleDesign variants, which may have different controllers (same with ANSI)
Can some of you please check what's inside their keyboards ?
Thanks for the help
What's needed
- Tester68 keyboard from CIY- A dead AppleDesign keyboard
- custom PCB
Build log
• Solder everything on the back of the PCB. The controller needs to be socketed• Cut every leg as close as possible to the PCB
Builds
To give you some ideas, two keyboards are already build:Myself
@Paulie 's keyboard
Thanks for the help
