This is really interesting. Thankyou for sharing the pictures with us. I think your use case is one of the most interesting of anyone on these forums.Someone once asked me how we are using these units, and my boss said it was okay to explain our set-up.
That’s the biggest can opener I’ve ever seen!!Someone once asked me how we are using these units, and my boss said it was okay to explain our set-up. We run three machines that use very old Macs to tell them what to do. Here are a couple of pictures:
It's not the easiest road to travel. It's a completely foreign world to what most Mac users know. THE SCSI2SD adapters we bought last year saved our butts when a heat wave (like we are having now in Ohio) hit and our old SCSI drives started failing one by one. Once I got the first SCSI2SD working, I literally cried. The operators love them, because the seek and load times are drastically reduced. The Macs fly. The SD cards are so much less susceptible to damage from the heat and dirt, it was a no-brainer to set up all of the machines to use SCSI2SD.Wow, I'm amazed some older macs are still doing duty in CNC shops! So cool to see! Now I understand the comments about dongles and PAC software.
Absolutely! See my response to Mr SN for more info. I can try to get some photos of the inside of a console if anyone is interested in seeing it.I'm guessing the machines connect to the Mac with a Nubus expansion card?
Thanks! We bought several of these machines used so we could keep doing what we are doing and expand our capacity. We even purchased a Laser/turret press hybrid made by the same company so we could keep using the same programming software.Wow, this is the only post I've ever seen on these forums of a machine being used in production. That is just awesome.
You're welcome! Interesting is one way of putting it, haha.This is really interesting. Thankyou for sharing the pictures with us. I think your use case is one of the most interesting of anyone on these forums.
Snort! That's the first time I've ever heard it called a can opener! We make all kinds of crazy things on those. I've attached some interesting photos of big things and little things that we've used those machine to punch out almost if not everything you see in the picture.That’s the biggest can opener I’ve ever seen!!
I will keep that in mind, thanks!I'm happy to do whatever you might need in terms of help to keep those old macs in business
I am working on that.Also I‘d love to see more about the actual cards/interfacing setup if that’s possible.
I prefer the mechanical hard drives too. Less trouble to configure. Unfortunately, they are very difficult to procure now. The SCSI2SD should be able to withstand 90°+ shop temperatures with 95% humidity and the pervasive grit and grime of metal fabricating (Did you SEE the keyboard pic?) a little better since it has no moving parts. The boys love the speed boost, so that's a plus as well.’m usually a stickler for mechanical drives, but maximum reliability is absolutely crucial in situations like this.
