Control Dock??
Bunsen
Admin-Witchfinder-General
That's called the Control Strip. You'll have to switch it on in the Extensions Manager - I think there's both an extension and a control panel. Then reboot. If it's not in EM, it's probably not installed.
Anonymous Freak
Also, it's only included in System 7.5 or later (unless you have a PowerBook 500-series, in which case, it came with the copy of 7.1 that came with those machines.)
Olympiaman1010
Control Strip huh? Hmmm, I can't find it though anywhere. Do you think because it was in a school they deleted the extension? Is there anyway to get just that extension? Or would I have to reinstall 7.5.3 which is what I am currently running.
Olympiaman1010
*Update* Ok, I used tomeviewer and put the extension into the control panel. Any ideas why it would give me this message when I try to open it "The control panel "Control Strip" cannot be used with this Macintosh." It is a LCIII with system 7.5.3, from what I thought the control strip was used... Anyone???
Dog Cow
You probably need a newer version of Control Strip, such as the one that came with System 7.5.3.
