Conquest-ish... PB G4 A1046
t3h
Bought this for $40 on an Australian "overclocking-related" forum. Seller forgot to mention that it didn't include a power adaptor, and described it's condition as "locks up occasionally when using it, probably just needs a new HDD".
It got half way through the OS X installer and this happened.
Rebooted and this happened.
Now it's totally dead :|
Should I try and fix it, or would I get more parting it out?
Byrd
Hi,
was that on OCAU? :)
I picked up two PB G4s off there recently, one was a PB Ti 667, which I got working 100% by cleaning the RAM slots. Fixed it up, gave to a friend - total cost about $40! It was in good nick too.
The other - a 1.2Ghz PB Alu model - worked OK, but wouldn't start up after being used for a while - probably PMU/motherboard fault which I could not diagnose.
With yours, I'd pull the RAM first, and see how you go running off a single stick. The top RAM slot often fails in these models. Try also a power manager and PMU reset.
JB
LCGuy
LC Doctor/Hot Rodder
Eeek :-/
I'd try Byrd's suggestions - also make sure you're using known-good RAM (that you've tested in other systems), and try both slots. Also consider trying an external display.
Failing that it looks like it could be a motherboard issue...perhaps the GPU considering the funky display pattern.
