I think you are right Paralel. I pulled the board and looked at it under high magnification and a strong light. It looked OK to me. But posts here make me think it is a multi layered board, with traces inside. Or it could be on the board with the fly back transformer.
I have unplugged and plugged back in all the connectors many times and sprayed so much contact cleaner in every crevice, that I worry I am washing the traces away on the boards.
I can now leave the CC for about 24 hours with the back power switch off. When I turn on the power and boot from the keyboard, it will boot every time. And, when I leave the back power switch on, and walk away, I can always boot from the keyboard many hours later.
What is odd, it that I can not select "restart" from the menu and have the CC reboot. It will give me one chime, a blank screen, and then sit. It will do this all the time. This is not intermittent.
Other then that, it seems to work perfect now. I will just have to wait and see what happens I guess....
Thanks for the feedback.
jack
