Thanks folks for the many tips.... This is what I have tried in the last 24/48 hours:
1) I left the rear power switch on while I was at work and overnight. Then I turned the soft power switch on via the keyboard. No joy.
2) I removed the analog board and inspected the rear connector under a magnifying glass and high light. I could not find any problems. No dust, no dirt, no bent connectors. While it was out, I gave it yet another quick shot of contact cleaner anyway. Then I sprayed a little compressed air on it, and let it sit to dry.
3) While I was in the cleaning mood, I took my can of contact cleaner and sprayed into the socket the analog board sits in. I did this before maybe 6/8 months ago when the CC was totally apart. After a good spraying, I turned the CC down on a soft towel and let gravity drain out the excess contact cleaner. I let it set overnight.
4) I installed the analog board. With my hard drive connected, I attached power. When I turn the power switch on in the rear of the CC, I can here the sound which I believe is the sound of the CRT turning on.
5) I press the key on my keyboard to turn on the CC. I hear the fan spin up. I received one happy chime. Nothing on the screen. Nothing else.
I did not try Elen's experiment of removing the case and then apply power, and then turning on the CC with the keyboard. I need to set this up in the dark so I can see if I can see any light from the CRT. I hope to try this tonight.
While at work, I went surfing on the net to find others who have the same issue. I read one post about a person who had the same issue as I do. He found that he had a bad capacitor in his keyboard. He replaced it and all was well. I do not have a spar keyboard to swap out. I have not taken a keyboard apart before.
Should I pull the power on my hard drive, boot, and look for a not happy face on the screen?
Other thoughts?
If it is a analog board issue, I do have working a re caped, and cleaned 575 analog board. I know I can just slide the analog board in. But as I understand it, I have to re edit some files, so the 575 analog board can supply 512×384 to my CRT? I am not sure how much work in involved in converting my CC to 640 X 480. And I would feel better about doing this 575 upgrade if I have a working CC to start with.
Any thoughts?
Thanks everyone for hanging in with me for so long. I am getting close I think.
jack
