mraroid
Hi folks...
I have enclosed some photos.
A few days ago, Elfen asked me to take the case off the CC, and see if the CRT would light up in the dark. I did not get to that suggestion until this morning. I should have done it sooner.
With the CC assembled, the hard drive installed, and the case removed, I turned on the back power switch, then the soft power switch on the keypad. I hard the familiar sound of the CC coming alive, but no light what so ever on the CRT or neck. I repeated this again and had the same issue.
I know of the power connector on this board. I would like to pull the power connector and look for 5V and 12V on the pins on the board. Can I do this with the CC powered up with out damaging anything?
On this board I found a two prong connector with nothing connected to it (see a photo of my finger pointing to it). It is BD-11. I found a second two prong connector under the CRT (see a photo of my finger pointing to it). It is also not connected to anything. I could not read the stenciled lettering for this connector.
I found a fuse near the power supply. I suspect that since I have good 5V and 12V on the power connector to the hard drive, then the power supply is putting out voltage (?).
This board has been re caped and cleaned by Uniserver with in the last 6 months.
I tried a coin test and tapped on the CRT. I am not exactly sure what I should hear. But to my untrained ear, the tube sounds good. An inspection of the tube found no cracks. It looks to be sound....
A few months ago, when the CC was apart, I cleaned the connector on this board as well as the connector it slides into. I could probably take the entire thing apart over the weekend and put it back together if need be.
But I think that if I see no light in the neck of the CRT in the dark, when I turn on the CC, maybe I am not getting voltage to the tube???
Thoughts?
Thanks again for all the tips.
jack
Thoughts?
jack
