Since I have to crack the case again for the installation of a new system fan, because the original is loud an annoying and low-speed quiet fans are awesome, I was thinking about 'installing' a speaker grill in the side like the later revision Classic 2s have. Is it worth it? Sound doesn't seem too bad as is.
If someone could do a rubbing of the factory grill on graph paper and get a bit of the nearby case seam for reference it should be pretty easy to drill the appropriate holes in the right spots. I've tried searching for such an image and haven't had any luck.
