jessenator
I've had very isolated issues with either of the CF cards used (with the appropriately "cheap" IDE adapter) and wonder if the following from an older thread is the solution:
For kicks I installed Norton Utilities 4.x.x and it can never seem to repair the issue (while booted from a different partition). I haven't yet made a bootable CD image that will work on the 4400 (system enabler…), but that's in my plans.
The 32GB CF card was originally set up either with DriveSetup from the OE 7.5.3 4400/200 restore disk or the 7.6.1 retail disc, but my money is on the 7.5.3 version. Should I seek out an alternative drive utility that can manage the aforementioned alignment for SSDs? Also, I did partition all the available space— there's the primary partition of 2GB and then two secondary partitions for storage split with the remaining ~30 GB. Should I start over and leave a bit of "free space" on the card as mentioned in the quote above?
Also, I'm not using VM as I read it will excessively wear out SD and CF media. I'm using a SanDisk Extreme, so bus speed disparity should be ruled out(?)
While running Norton, I would get massive batches of errors (mostly creation dates because I've hit that CUDA reset more times than typically would've been) and they never seemed repaired, as mentioned earlier. If there's a better utility, I'd be interested in knowing what it is.
Thanks!
When writing or loading savegames (specific—the only instance this error consistently comes up) I'll regularly, but not constantly, get a disk error (and now I'm away from the machine I can't remember the ID…) which I think is related to the Catalog File on the disk.You have to use newer utilities designed for solid state memories. And chose HFS for a partition. I think the newer partition magics can do it.
Also there is a free utility that I use that will take an existing partition no matter what it is, and re-align it on its own as long as there is some freespace. I think its AOMEI or something along those lines.
Otherwise if its not aligned, your going to have consistent corruption issues. As much as I love solid-state memory as disk drives, They aren't really friendly with older file systems. Some SSD utilities can handle older filesystems, and some cannot.
Also if your using CF cards with built-in wear leveling, Dont partition the whole card... Partition only 75% of it, so that leaves free-space for the controller to use that area for sector wear leveling.
Thanks!
