Retronaut
This is a re-post from Apple Fritter forums, as this is a pretty specific problem, I thought it best to spread my net wider...
Hey, I am relatively new to the Apple IIgs, and in my enthusiasm to get it up to the level of an Amiga 2000, I decided to buy a SCSI card, and ideally install GSOS to a hard disk and boot from it. This seems to be, possibly a faster method than booting from a smart port disk?
So to do this I bought an A2SCSI card from GGLabs a couple of years back, and only now am I installing it, as I also have an Apple Squeezer card. With the two in place, the machine should be pretty sweet. But not quite yet...
So, the rub... Having installed a working GSOS 6.0.4 installation to a Smartport disk using an emulator and a FloppyEMU, I can get my IIgs to boot to GSOS 6.0.4, which is all good. When booting OS complains (at differing points on each boot) that it cant load in the hard disk, because this requires drivers... which is kind of expected. The GGLabs site, provides a disk image of those drivers, and I have installed these into the 6.0.4 install, using its supplied installer, but sadly after a reboot, the issue persists.
I have used another disk that GGLabs provided, a SCSI Utility that can check the Hard Disks, and partition them as well, but this only works AFAIK when booted as a floppy. The same utils do not appear to work when your IN GSOS, which is a little frustrating (but this was the 80s after all...
)The good news is, it saw all 5 SCSI drive images I had put on a BlueSCSI and reported them all at their correct sizes, 32mb each, and one at 256mb as an experiment. And I can also choose one of the 32mb drives, and partition it, though oddly the Util only seems to allow me to add two partitions of 10mb each.....
So, now I find myself in two worlds. GSOS WITH the correct drivers installed, refuses to see the BlueSCSI's Drives during or post boot, even when partitioned. But, if I boot from the SCSI Utilities disk (floppy) I CAN see them. So it appears the A2SCSI card IS working perfectly fine, and having read the manual for the original card it was based on, it states there it CAN be used as a boot device for a IIgs.
Does anyone know what the magic sauce is here? Is it an issue with GSOS 6.0.4? I assume not as it was recommended because it fixes various bugs, so I assume it is MORE compatible with hard drives etc, not less. Did I install the drivers incorrectly in some way?
And the original manual for the original SCSI card that this card is based on, is VERY technical, but never goes into the nitty gritty of how to install it on a IIgs for example.There appears to be a missing link. You'd assume there would be an official install Floppy disk set for this card, but...Any help appreciated, its not a hardware issue here, its software (or me)
