davidg5678
I am working on a Macintosh II motherboard which will not boot up. It has been recapped, cleaned, and has had new batteries installed. Using this excellent article, I checked for continuity throughout the entire power circuit, and I have patched all of the broken traces I could detect. I have confirmed that there is a connection between R3, R18, and C6, as I read that this often goes bad. For good measure, I also added a patch wire from C14's positive side to UI14's pin 10. I desoldered UB1 and UB2 and cleaned their pads before reattaching them to the board.
When I press either power button, sometimes the PSU turns on, but sometimes nothing happens at all. The power button on the back of the computer turns the machine off, but it then immediately turns itself back on. There is never a boot chime and nothing ever appears on the screen. I verified that the PSU voltages are normal. Sometimes I can make the PSU turn on with a jump-start, but the computer still does not boot, and even the ability to jump-start is intermittent.
When working on this same board a few years ago, (with significantly worse equipment and skills) @AwkwardPotato recommended that I check pin 8 of UB2's voltage while pressing the keyboard power button. Apparently, the voltage is supposed to drop to 0v from 5v when the button is pressed; however, I have never measured a voltage at this point that is higher than 0v. The pin always seems to be pulled low. (assuming this is the correct terminology) I also measured voltages from the NAND gates 3 & 4, but they seem to be behaving abnormally. Instead of changing from 5v to 0v when a power switch is pressed, their voltages remain at 5v. I think this is part of why the computer is not turning on, but I am not sure how to proceed. (Maybe a component is defective, but I don't really know how to tell.) At least Q3's emitter is measuring within the right range.
The computer doesn't chime -even on the rare occasion I can manage to get the PSU to turn on, nor is there is not a video signal. I am unsure whether or not this is a related or separate issue from the power circuitry problems.
If anyone has any ideas or advice about how I can fix this computer, I would love to hear it! Thanks!
I've placed AwkwardPotato's quote below along with a few links to some other, older posts for context.
Measure the voltage on pin 8 of UB2 too, this should be 0V when the keyboard switch is pressed. Measure the voltage at the emitter of Q3, it should be around 5-7V at all times.
In a working power-on circuit, gates 3 and 4 (rightmost ones in the power-on circuit) should output 5-7V when neither switch is pressed, until one of the switches is pressed, at which point it goes to 0V. The output of those gates then goes to the base of the PNP transistor at Q3. To turn on that transistor (let current flow from the emitter to the collector), the voltage at the base should be lower than that at the emitter (which is always at 5-7V). Since the collector is connected to the pin that turns on the power supply, the base needs to be pulled to 0V to turn on the computer.
