tt
The machine's power supply turns on, powers the drives, but no boot chime sounds and I think there is no video. This Quadra 950 has worked in the past, but it had a logic board that was not fully seated in its plastic frame when I received it and I guess it shifted again when I moved the machine. I noticed the reset and interrupt switches were being pushed into the end of buttons. I am wondering if they got strained from being pushed on for a long time.
Can someone please measure the resistance of their S1 switch (marked on the board / triangle button)? I measured it across the two top exposed conductors, so it is not necessary to remove the board to take a measurement. I measured S1 and the resistance was on the order of 130 ohms. I feel like that value is too low, but I measured S1 on two different SE/30 logic boards and it is around 350 ohms (so some lowish resistance might be normal?). S2 is fully open when not pressed.
Other checks I did: Measure the voltages coming off the PSU which look good. Swapped out the RAM. Disconnected the hard drives. Smell test for burned components.
