DontGetHit
Okay so the power supply was working before I recapped it. Then I recapped it and it was working again until it wasn't. Sometimes it wouldn't boot up. Pressing the power button would do nothing. Then when it does boot up it will work for a bit but then switch off. I used the console5 recap kit and I know that some of the caps weren't perfect replacements but I also know that a cap does not have to be the same values to work. Does this fault point to anything else perhaps? is there something on the logic board that could cause these problems?
tldr: IIsi sometimes doesn't turn on and when it does it will shut off shortly and then stop turning on. PSU and Logic Board have been recapped
