fergycool
My recapped Quadra 610 has started becoming a bit problematic. This all started when I'd been trying to get the CD Rom drive working (I'd recapped it but it still does not work) so the Quadra had been on all day.
A few times in the past there has been no boot chimes. Generally I'd found powering down, turning off at the mains, leaving five minutes then booting back up always worked. I guessed that it was the PSU that I knew needed recapping.
Since having the Mac on all day this problem had been getting worse. To the extent that it would never warm boot. If I restarted it was fine. But if I shut it down and turned off then I always had to leave it turned off for some time. Sometimes even overnight.
I thought it was time to recap the PSU. However, even though I know I should have recapped it myself I was quite daunted by the task and I saw this company selling refurbished vintage Mac parts,…. including a 6100 PSU, which also fits my Quadra 610. In an act of weakness I went and ordered one (far too expensive!) which I regretted as soon as I placed the order (please do not judge me for throwing money at a problem rather than putting the effort in to fix it myself! Lesson learned - I hope….).
Anyway it came on Tuesday. I put it in the Quadra. Same issue started happening immediately. Over the past few days it's become far worse and now there are very rarely any boot chimes at all!
So either I bought a failed PSU or the problem is not the PSU at all.
A few months back after I'd recapped this machine I still got the chimes of death. It turned out to be a leg of a chip (RP3), which is surrounded by three caps, that had corroded. I added a blob of solder which sorted the problem. But the rest of the board looked good. I'd previously checked that all chips legs are making contact and they are. For some months it worked almost flawlessly (except for the issue mentioned above).
My initial thoughts were some sort of short. Only when it's cold is there a space, but when it's warm whatever is causing the short expands and touches. However, it does not have to be on long before it does not restart. For example the logic board has been in an unheated workshop all night. This morning I plugged it in and I got the chimes! I left it running for twenty seconds then turned off, then back one again. The chimes had gone.
So what could it be? Is something storing a charge that is only being discharged over time? If so why did it not happen before?
In the absence of any idea what the problem is my plan is to go through every chip on the board that's near a cap and reflow each leg.
Anything else I should be looking for?
Thanks!
Thanks!
