I did a clean reinstall of 8 when I installed it. (which the monitors & sound control panel was installed with so it should work) Control Strip wasn't installed by default. I copied all control strip related files over from my 4400 running the exact same system to the Q700. I opened it after putting the files in their places and restarted. When I opened it it said, "This isn't compatible with your macintosh" or something like that. I don't see how the control strip should have any hardware requirements. I also tried resetting the PRAM which didn't work.
System 7.5 is installing right now. I'll see if I can get color with that. ;D
