Yeah...i see your point, but i still think its unethical to read someone else's documents without their permission. Look at it this way...lets pretend you don't own a car, but you see one sitting in the street unattended with the driver's door open, the windows down, the key in the ignition, and the engine running. Would you drive off in it "just because its common sense to not do that"?
Btw, MacTCP, maybe you could enable the control strip and try changing the bit depth that way...unless someone's mucked about with the contents of the Control Strip Modules folder, there should be two modules for graphics settings: one for changing colour depth, another for resolution
