sutekh
Well, I officially need my head examined. I threw a low offer out on an untested "parts" PB 180c, and to my surprise it was accepted and arrived today in one piece. It's a wreck though. Its installed aftermarket NiCad has leaked and was fused in place. Plastic at the hinges is of course broken. It's filthy dirty, missing the ring around the trackball and the port cover, and didn't include a power transformer. I've wanted a 180c for years (had a 170 in college and lusted after them), but planned to hold out for a nice one. What am I doing with this basket case?
I was able to delicately pry the rotten battery out and get the case open, and to my relief, nearly all of the battery leakage is isolated the the battery compartment. I pulled every board out and both them and the chassis just to be sure. After a quick cap inspection, I decided to try feeding it 7.5.v from my bench power supply. Chimes of death :'( I had a spare daughter and memory board knocking around, so swapped those in and was this time greeted by the normal startup chime. Great! And a blank screen. Less great.
The floppy clicked, the HD started chattering. Something was happening, but LCD remained blank. Having been on the hunt for the right (i.e., not this one) 180c for a while, I'm all too aware that their LCD ribbon cables are a major weakness. Fearing the worst, I opened the screen and, sure enough. Cut completely in half right at the hinge. Damn. Guess I'm going to be splicing together a ribbon cable :O I've seen a few threads where others have tried this with varying degrees of success. Seems like the problems arise from using individual, unshielded conductors that end up picking up interference. I'm planning to sacrifice an 80-pin LVD SCSI cable owing to it's densely packed conductors. Wish me luck...
