Elfen
This repair was rather simple, but Digikey sent a substituted part. I ordered these clips as they are the same ones used on the LC PSU connector. They sent another type that does fit the pins on the motherboard. But it was a rabid female dog to put it in the plastic Molex connector.
This LC-TDK failed because for some reason the connectors corroded and pulling on the wires, they popped off with a broken clip on the end! Trying to shove the wires back in the connector made the LC make a "Flub Flub Flub" noise when it was turned on. The corrosion on the remaining clip was black on the silver part and green on the inner copper core.
The PSU also needed a recapping but the connector clips needed to be replaced first. Replacing it fixed the PSU that it can turn on an LC. But it also produced a fish smell indicating that the caps need replacement.
Biggest hints as to the clips needing replacement -
1) the space where the clip is in is dark, almost black.
2) When you grab it and pull on it, a wire pops off. You wont be able to get it back in to make a good electrical connection.
3) When you try to fish the remaining connector out to try and solder it, it falls apart.
4) Solder wont hold onto the corroded pieces.
To replace the connector, you need to pry open the clip at the wire end and pull the wire out. Cutting the wire and trimming the insulation will make the wire harness too short and you need to pull and stress it to get it on to the board. The wire needs to be as intact as possible from the clip.
Since I had to use a replacement clip, I had to fudge with it inside the plastic of the connector until it fit and lined up inside. And like I said, it works without the "Flub Flub Flub" noise, though the fish smell says it needs a recap. That's next on the list.
