Bolle
U92 is the RTC/PRAM.
Without it you will get exactly what you are seeing now... booting from floppy works but SCSI doesn’t + periodic blinking on connected devices.
Had that before on a SE/30 with broken PRAM chip.
One of the VIAs is communicating with the PRAM on bootup. If that communication fails the machine won’t boot correctly.
