Hello,
I've managed to return a tiny bit to my 68k Mac hobby and decided to try to clean up an unmolested backlit Portable I had lying in the closet.
What I've done:
Now, after connecting a charged and correct battery I'm getting this:
No chime from the speaker, just a really silent crack (the usual sound of a device turning on) when the power manager is reset. The computer reacts to both the interrupt and the reset button with silent high-pitched sounds of different pitch. Resetting (with both buttons + spacebar) multiple times leads to the same image on the screen.
Nothing gets hot or even particularly warm to touch. The voltages look correct, +5.2V and +11.2V.
The condition of the board was good, waaay better than the SE/30s I worked with. There are a few places where the solder joints got a bit dull, but nothing as tragic as I've seen on other Macs. The suspect places are:
Thanks a lot and all the best in 2022!
What I've done:
- Didn't try to turn it on, just disassembled it.
- Desoldered all capacitors. Most of the cap juice seemed fresh and still mostly under the caps. It looked like C205 (the 4.7u one) leaked the most.
- Washed it thoroughly with water and then IPA.
- Baked (~70*C) it in the oven as @techknight recommended in multiple posts and then dried it for several days.
- Soldered new caps of good quality (Polymer Tantalum instead of SMD cans, properly derated). I'm relatively confident about my soldering, I did quite some SMD soldering and rescued several SE/30s and Classics.
- U5L (LT1054CS) which I already desoldered, cleaned underneath and resoldered
- U5K 74AC138 both rows of pins have dull solder
- U5H 74AC244 one side dull
- U13C 74AC244 one side dull
- U13D 74AC257 one side dull
- U14A ASC one side dull
